multi - power
charles mcclint
02-20-2005 08:18:10
is there a quick or easy check to see if multi power is bad without tearing the tractor apart,
freewheels in hi an lo range now,,,,on 135 massyferguson,,,,,
acmfmh
02-20-2005 11:50:29
 Re: multi - power in reply to charles mcclintock, 02-20-2005 08:18:10
A MF135 should not freewheel in high on the MP. If it is freewheeling then the MP is not working. Also check the linkage make sure it is actually shifting.
Lee in MI
02-20-2005 10:50:28
I just loaned out my factory service manual, so can't tell you off hand what the pressure should be on 'HIGH'. A good investment is the CD that Big Dean puts out on the 100 series, I have one along with the factory service and IT manual.
Lee in MI
02-20-2005 10:45:29
There is a pressure test port on the left cover down by the PTO lever. If you have a cooling/filter behind the front grill, you can test at one of the lines that come from the bellhouse on the left side of the tractor. Check Big Dean's website, he's got most of the info on there.
