mf35 diesel dual clutch splines
brian in indian
03-08-2005 15:47:15
can anyone tell me how many splines are on the shaft for the clutches on a "61 MF35 perkins diesel tractor with dual clutch
brian in indiana
03-08-2005 17:45:16
 Re: mf35 diesel dual clutch splines in reply to brian in indiana, 03-08-2005 15:47:15
yes it does thanks for the info.
Sodbuster
03-08-2005 17:40:59
There are ten (10) splines on the small shaft that seats into the pilot bearing of the flywheel. There are ten (splines) on the shaft that the clutch release bearing travels on. I have the same tractor as you and mine is split waiting on a clutch. Just went and counted them. Hopes this helps..... ...
txblu
03-11-2005 06:11:17
 Re: mf35 diesel dual clutch splines in reply to Sodbuster, 03-08-2005 17:40:59
The springs on my 35 with Live PTO seem a lot stiffer than my Ford's. Do you find that it takes a lot of pressure to push the pedal down?
