THANX !!! to Big Dean MF 40 industrial now drivin
chris thompson
03-14-2005 04:32:00
Hello Big Dean the massey 40 industrial is now operating my neighbour added the correct quanity
of 134 hydraulic fluid and now its working good exept that it revs the engine a little before it goes into gear and jerks on engagement but i think he has a linkage wear or adjustmant issue as it pushs untill it spins tires or stalls engine any ideas about the jerking is there any other problem areas ??? anyway i wanted to thank you for your help as your always willing to lend a hand to help someone out and thats very nice!!!
THANX!!! Chris Thompson
Big Dean
03-14-2005 11:56:42
 Re: THANX !!! to Big Dean MF 40 industrial now dr in reply to chris thompson, 03-14-2005 04:32:00
Chris It has been several years since I worked on one of the MF40 but the best I remember there is a spring that runs from the pedal mechanism to one of the transmission top bolts it is to make the transmission engage before the throttle start to open if that spring get stretched or weak the engine will rev up before the transmission is engaged causing the tractor to lung when the transmission is engaged. Also if the engine is idling to fast it will lung when the tractor is engaged.
