Big Problems??
AL165
03-20-2005 11:07:27
OK, I'm not a big mechanic however i know when something don't look right. Today i was under my 165 just looking around when i noticed what appeared to be a plate missing on the bottom front of the transmission housing, and i believe what i am seeing when i look inside IS THE CLUTCH!!!. I'm hoping some master mechanic will tell me that all 165's have a big hole in the bottom on the transmission...but i doubt it.
shingi
04-06-2005 19:12:29
 Re: Big Problems?? in reply to AL165, 03-20-2005 11:07:27
i got a mf 399 and big problems in deed.
this tractor has two setting 540/1000
i need to figure out why the pto does not disengage while the engine is on. but the setiings has a hard time engagging with the tractor on.(it grinds)
any ideas????? why.
DavidP,South Wales
03-21-2005 12:11:39
Hi Al165
For once the problem is only minor and the solution easy. It is essential to have a plate under the clutch access point to keep out water and debris etc. Plates from MF35 upwards will fit or make your own if you can. They are normally 1/8" thick and
are exact shape of the casting face. You don't need 4 holes 2 diagonal ones will do.
Ben is right about 5/8" UNC but 1" to 1 1/4" bolts will be quite satisfactory. 2" might well bottom.
Cheers
David P
ben uk
03-20-2005 12:22:47
Its ok...its meant to be there....should have a plate over it though.
You have to go up though there to adjust the PTO clutch...
Should have 4 bolt holes in a rectangular pattern there - get a plate/make a plate and bolt it up there. Dont want water going in there if you drive through a flood or something!
The bolts are 5/8 UNC and about 2 and a hlaf inches long.
Ben
AL165
03-21-2005 16:29:31
 Re: Big Problems?? in reply to ben uk, 03-20-2005 12:22:47
Thanks,
I checked today to see if one could be ordered and the guy told me no. I guess i will have to find a junk one somewhere or try and make one.
DavidP,South Wales
03-22-2005 12:54:13
 Re: Big Problems?? in reply to AL165, 03-21-2005 16:29:31
Hi,
Have you tried these numbers:-
4 Hole plate 180 482M1
2 Hole plate 964 167M1
Bolt 353 901X1 0r 354 441X1
Cheers
DavidP
AL165
03-22-2005 13:52:39
 Re: Big Problems?? in reply to DavidP,South Wales, 03-22-2005 12:54:13
Thanks, I will try these
AL165
03-22-2005 13:52:26
