Master control spring - what for?
Bill Darte
03-28-2005 06:01:55
I have a general question....
I'm back to looking at the boot that covers the master control spring and shaft.
What is that whole mechanism for? Is it part of the draft control mechanism? What is the impact to operations if it is poorly adjusted? I presume it will have NO impact on bush-hogging...
Thanks for the info...as alway.
bd
Louie
03-28-2005 08:32:07
 Re: Master control spring - what for? in reply to Bill Darte, 03-28-2005 06:01:55
It will not interfere with bush hogin if you keep the draft control all the way up. If the draft control is not all the way up, whenever you hit an uneven spot the cutter will lift up and the top arm of the 3 point hitch will push the master control plunger in. This will cause the bush hog to lift up. This gives you a very uneven cut.
