Checking Planetary Gear Oil
AL165
04-03-2005 19:22:42
On a MF 165 does anyone know how to check/add the Planetary Gear Oil?
Big Dean
04-03-2005 23:37:15
 Re: Checking Planetary Gear Oil in reply to AL165, 04-03-2005 19:22:42
There should be a plug in the center section of the planetary on the back side to check and fill the planetary it fills to the bottom of the plug hole. I have found several of them that had been apart and the center section put back with the plug in a different location
AL165
04-04-2005 19:28:37
 Re: Checking Planetary Gear Oil in reply to Big Dean , 04-03-2005 23:37:15
This needs to be filled with regular gear oil correct?
Jeff-oh
04-05-2005 13:06:31
 Re: Checking Planetary Gear Oil in reply to AL165, 04-04-2005 19:28:37
The MF-65 manual calls for the same GL-1 gear oil as the transmission.
