Removing the lift and draft lever mechanism
Bill Darte
04-08-2005 11:54:34
Is there any 'danger' in just removing the lift and draft lever mechanism from the housing outward in order to strip, paint and decal them in the shop? I would then 'simply' replace them later after painting the main tractor elements? Are there 'gotchas' in this?
Thanks again!
bd
Thomas
04-08-2005 14:44:29
 Re: Removing the lift and draft lever mechanism in reply to Bill Darte, 04-08-2005 11:54:34
There is no particular "danger" but you will need to set everything up correctly when you finish, which if you"re taking the lift head off I would do anyway. If you follow the MF workshop manual procedures it is not dificult.
As far as I am aware these parts should not be painted, have them shot peened and zinc plated to get an original finish. I"ve done a few this way and they look really good even several years down the line.
Gerald J.
04-08-2005 14:18:22
The I&T manual calls out a process for adjustment so they work again after reassembly and thats with the rocker cover off to start with. More after you put the rocker back in place. And that takes three strong backs or a crane.
Gerald J.
