M-H 44-6 Oil pressure adjustment
Brian Kaldunski
04-10-2005 19:18:23
on my 51 M-H 44-6 the cam bearings are worn so when she gets warmed up the oil pressure drops down to 5 lbs. on a prior post i was told about a bolt on the block that if i put a washer behind it would raise the oil pressure. Do your recomend this as a short fix until i can afford to get new berings pressed in?
msb
04-10-2005 21:36:58
 Re: M-H 44-6 Oil pressure adjustment in reply to Brian Kaldunski, 04-10-2005 19:18:23
I think the bearings only cost me $18 if I remember correct and the labor wasn't very much either.The gasket set is kind of salty though.
