4x4 fergie
backhoejoe
04-16-2005 11:42:24
Has anyone thought of trying to convert any little fergies to four wheel drive. Im thinking that it may be fun to try.
Roy in UK
04-16-2005 22:56:15
 Re: 4x4 fergie in reply to backhoejoe, 04-16-2005 11:42:24
There were odd ones kicking about in the UK. The conversion kit was supplied by Selene. If I find a pic I will post it on here
Roy in UK
04-16-2005 23:14:44
 Re: 4x4 fergie in reply to Roy in UK, 04-16-2005 22:56:15
Bullseye! look in Vintage Photos I just put one in
marlowe
04-16-2005 14:45:31
there is no side port on the trans for a gear box to run the front end but then you might use a hyd. drive front end
backhoejoe
04-16-2005 15:52:05
 Re: 4x4 fergie in reply to marlowe, 04-16-2005 14:45:31
I was thinking of machinning a hole in the side of the trans then between the trans output shaft and the pinion there should be a sleeve that connects the two that you may be able to weld a sprocket on and chain drive it out to the side of the tranny to a shaft that would run up front. The cast thickness of the tranny should hold up with a little help for mounting the second sprocket.
Manuel
04-16-2005 18:32:13
 Re: 4x4 fergie in reply to backhoejoe, 04-16-2005 15:52:05
I was reading about somebody that converted a grey fergy & dexta [I think]. He puts in a spacer with a hole for the drive..... .
