Massy 65 with loader
Brian S, NE
04-29-2005 19:26:10
A friend of mine picked up a Massey 65 (I think it's a 65) with a FEL on it. When he raises the loader, the 3 pt raises as well.
I am assuming that this is a new enough tractor that the hydraulics wouldn't be something gobbled together out of a test port or something like what is done on 8Ns and then require the 3pt to be chained down to work right.
Anything I can have him look at or any suggestions on what might be the issue?
Thanks
Brian S, NE
Rednight (IL)
04-30-2005 05:56:36
 Re: Massy 65 with loader in reply to Brian S, NE, 04-29-2005 19:26:10
My 65 has a 2 spool valve with levers in front of the seat. When I use the loader I kick the left lever (rear lift on mine) forward in neutral and pull the right lever in. Just the opposite for the 3 pt. Also when I use my trip loader I will set the draft lever all the way down and just use the spool valve to raise and lower the loader. A lot faster!
