What rear tire size for MF 165?
anothertractor
05-13-2005 07:49:55
Hey y'all,
I have a friend that has a 165 MF with a loader and it has 16.9 x 30 inch tires and he says that he has 15 x 30 inch wheels. The wheels have rotted out and he wants to replace them. He is having trouble finding these rims. (He actually found some for $550 each) Do you know if this is the size that would have come on this tractor? I don't understand why he is having such a hard time finding the rim if this is what came on the 165. Does anyone have a source for these rims? I told him that we might have to find a donor rim and get out the welder.
lancemustaffa
05-16-2005 09:34:24
 Re: What rear tire size for MF 165? in reply to anothertractor, 05-13-2005 07:49:55
I have a set of 30" poweradjust rims I was going to use on my 180. I no longer have that tractor so I would let these go cheap. Bolt pattern is 8 x 8 There are 18.4 mounted on them but the tires are shot. I don"t know where you are from but I am in Michigan.
CEB
05-13-2005 11:06:24
According to my equipment guide, 14.9-28 was supposed to be the most common size tire. I used to have a 165 and it did have the 14.9-28's. I thought that tire size looked about right for that tractor. I know that have seen several 165's with row crop 15.5-38 tires, but I can't say that I've seen very many with 16.9-30's. If you have an owners manual, they will generally list all the tire sizes that were available from the dealer when the tractor was new.
Bob N.Y.
05-13-2005 16:22:19
 Re: What rear tire size for MF 165? in reply to CEB, 05-13-2005 11:06:24
Most 165 standards had 28" wheels, but the very late ones were on 30". I expect this tractor has square axle housings and possibly the 8 speed transmission. Other models had 30" wheels so rims should be available.
Crem
05-13-2005 21:33:37
 Re: What rear tire size for MF 165? in reply to Bob N.Y., 05-13-2005 16:22:19
My MF 165 has 18.4-26" tires, so there are a number of different sizes used on that tractor.
