DIESEL INJECTORS MF65
CLIFF
06-22-1999 19:16:45
I'm pulling the head on my MF65 and it looks like I must pull the injectors to remove the bolts which hold the head down. Am I correct in this step? Does anyone have any suggestions to make this job easier?
Thanks
Cliff
Jack in NB
06-23-1999 16:01:02
 Re: DIESEL INJECTORS MF65 in reply to CLIFF, 06-22-1999 19:16:45
Hi Cliff -
You are correct - sounds like the earlier indirect engine with the vertical injectors.
I'd strongly recommend getting a copy of the I&T shop manual, or a reprint of ther factory manual - available from our hosts - at the top of the left column.
The manual may save you a lot of grief - and expense - in re-assembly.
Good luck!
