Massey Harris or Ferguson 50
Tommy D.
05-19-2005 10:20:35
Howdy all,
A friend of mine has a tractor and we're not sure exactly what hp it is. It says "Massey Ferguson" on it, and according to the dealer and serial #, it is a 1958.
The dealer is telling him it is a 50 hp tractor, and that's what the "50" stands for. When I look it up here, it is about 32 hp.
Was there a "Massey-Harris" 50, AND a "Massey-Ferguson" 50 with different HP??
I am sort-of questioning this dealer, as he has given my friend a couple of wrong parts already.
All guidance appreciated!
Tommy D.
Lou
05-20-2005 12:11:46
 Re: Massey Harris or Ferguson 50 in reply to Tommy D., 05-19-2005 10:20:35
I spent about 5 hrs on a MF 50 diesel yesterday.Ive owned it maybe 10 yrs, the diesel is a very good worker. Good Luck
Tommy D - Thanks Guys
05-20-2005 09:38:57
Thanks to all for the input. It is definitely a Massey Ferguson agricultural 50. Has 2-stage clutch and a remote on it too.
Tommy D.
Leroy
05-20-2005 03:35:39
The Massey Harris 50, Massey Ferguson 50, Ferguson 40 all share the same power train with the Ferguson 35
Ag or Indstr'l 50?
05-19-2005 19:36:35
Most parts should be the same, whether it's an MH or MF 50 agricutural tractor, and they do have the lower horsepower rating. If it's an MF 50 industrial tractor, however, it has the higher rating and most parts would NOT interchange with the ag models. I don't have the MF 50 industrial serial no's. but some could conceivably be the same as earlier ag models. Perhaps Big Dean could help with that.
Tom Dold
05-19-2005 15:25:24
Tommy
The Massey Harris 50 is rated at 32 drawbar Hp 34 PTO Hp. Basically same tractor as Ferguson 40. The Massey Ferguson 50 is a newer model of the same tractor. The Massey Harris 50 was painted Bronze Metalic on the engine and transmission (same color scheme that the 333 thru 555 used). The Massey Ferguson 50 was flint Metalic Grey. The MH 50 also had scallops in the hood similar to the 44 as opposed to rounded corners between the top and the sides on the MF 50.
Tom
Dold Implement Co.
Howard, SD
dold@alliancecom.net
9n141
05-19-2005 18:47:23
 Re: Massey Harris or Ferguson 50 in reply to Tom Dold, 05-19-2005 15:25:24
Is a MH 50 high crop rare?
9n141
05-19-2005 18:47:13
Tom Dold
05-20-2005 15:59:19
 Re: Massey Harris or Ferguson 50 in reply to 9n141, 05-19-2005 18:47:13
9N141
I assume you are refering to what Massey called the High-Arch. They are equipped with 38" rear tires, as opposed to the Utility which has 28" rears. The parts manuals however refer to them as High clearance or Low clearance so there is some confusion. The 1st letter of the serial # will give you the chasis type:
S - Utilty
R - Row Crop Twin
T - Row Crop Single
C - High Arch
J - Multi Purpose
The 2nd letter will give you the fuel type:
N - Diesel G - Gas
B - L.P.
H - High-Altitude Gas
The 3rd letter will give you the clutch type:
F - Single
M - Double
Then the serial number follows:
MH - 500001
MF - 515708
I don't believe there were any Massey Harris diesels. Nor do I believe there was any distinction in actual numbers for any particular type.
Tom
jrsn
05-21-2005 00:09:43
 Re: Massey Harris or Ferguson 50 in reply to Tom Dold, 05-20-2005 15:59:19
http://m-h.cs.uoguelph.ca/ Tom, this site has engine data for some of the MH"s . It seems some had diesels .. Ray-s
