135 on disc mower
Ben uk
05-25-2005 05:13:35
Hi guys
Im in the UK for a start
Off to a farm sale on friday, there is a 210cm drum mower and a "fahr KM22 drum mower" there. Im wondering if my 135 would be up to powering either of these in quite long and thick grass hay in the UK?
I dont really mind how long it takes, were only making about 17 acres this year and it will probably be in blocks of 5 acres.
Thanks guys
Ben
ben uk
05-28-2005 04:34:45
 Re: 135 on disc mower in reply to Ben uk, 05-25-2005 05:13:35
Hi guys
Didnt buy that disc mower..... complete wreck, i left before it came up so i dont know how much it sold for, but it was bodged everywhere!
4 bits of steel welded on top of the bed to hold it together! A random hole in the gearbox that had a bolt dropped in it with a load of sealant around it to try and block it up, fell out in my hand so would have been pissing oil everywhere.
thanks for the advice, maybe another day!
Ben
Roy in UK
05-28-2005 13:31:31
 Re: 135 on disc mower in reply to ben uk, 05-28-2005 04:34:45
Glad you walked away from it.
Look for a nice disc mower for her, (say a Vicon or a Lely ) about a 5 to 6 footer
DavidP, South Wales
05-28-2005 12:37:13
Wise man.
DavidP
Arthur from Tassy
05-26-2005 02:56:10
Hi all
I have spent lots of time cutting grass and clover (heavy crops too) between milkings.
I found the PZ cm165 was a good match for the multipower 135 diesel.
however the steering was not power assisted and did after a couple of days made the back of the neck ace! We also used a couple of front end weights to keep the balance right.
Cheers Arthur from Tassy
DavidP,South Wales
05-25-2005 13:46:36
Hi Ben,
I have a PZ CM165 drum on my 1965 135 which copes with it OK. In thick matted grass progress is very slow. I think that in these conditions your tractor would be on it's limit and a 165cm machine would be a better bet.
Without doubt the KM22 and CM 165 are the best machines around. Don't forget also that when in transport there is a lot of weight a long way back which will make the front end dangerously light especially if you hit a pot hole.
Cheers
David P
Big Dean
05-25-2005 10:48:42
Hi Ben If you buy that mower when moving around with it folded up be very careful I have seen probably at least 8 or 10 MF135s and MF235s MF245s turned over with New Holland disc mowers when turning to the left. On 2 of those the driver was killed.
Roy in UK
05-25-2005 10:20:44
third party image
Ben,
Do you mean 210 disc or drum ? sounds a bit to much for a 135. The Fahr KM22 (see picture)is about 5 foot 6 inch so I would be OK I think in 3rd low or 1st high if it was not too thick, but with the mower in transport position you would need quite a few weights on the front end to hold her down!
Hay Dr
05-25-2005 21:50:22
 Re: 135 on disc mower in reply to Roy in UK, 05-25-2005 10:20:44
third party image
I see a PZ CM135 without the shields over against the wall. In the States the CCM 135 is the same as the PZ CM135.
ben uk
05-25-2005 10:27:51
Thanks Roy!
Tractor should have a loader on it soon, just need to make the bracket, so that should hold the front down!
Our grass is thick, talking 860 bales of 7 acres!
I will only buy it if it is cheap!
Thanks
Ben
Roy in UK
05-25-2005 14:04:46
 Re: 135 on disc mower in reply to ben uk, 05-25-2005 10:27:51
860 bales of 7 acres... Someone been over zealous with the Nitram???
Yall sure as heck not cut it with one of them thur sickel mowers.
ben uk
05-26-2005 04:13:58
 Re: 135 on disc mower in reply to Roy in UK, 05-25-2005 14:04:46
Ha ha yer..... tend to get a bit carried away! lovely hay though!
Roy in UK
05-26-2005 05:34:52
 Re: 135 on disc mower in reply to ben uk, 05-26-2005 04:13:58
There will be some sap in that I guess! Heck I hope you don't get any heavy storms to flatten it before you get it 'loose at both ends' either, or then it definitely will be disc/drum mower or nothing.
Chuck (CA)
05-25-2005 18:01:36
Boy! I sure love those British accents. :-)
