mh 44 rear main seal
bob welton
05-31-2005 10:17:26
Hello folks..I need to replace the rear main seal on my MH 44...it has the mah260 4 cyl. gas motor...can this be done with out dropping the oil pan or pulling the motor? please help..... thanks bob
bob welton
06-02-2005 04:42:23
 Re: mh 44 rear main seal in reply to bob welton, 05-31-2005 10:17:26
Bruce thanks for that info!
Bruce Colbourne
06-01-2005 01:39:51
You will have to lift the motor out and remove the bellhouseing,clutch and flywheel.The new seals made for the H260 come in a kit with everything needed to mount it.You will have to drill the back of the block to accept the seal.When you lift out your motor make sure you keep the shims from under the front motor mount.They will have to go back under the mount when you put the motor back in.
