Loader is on!
ben uk
06-11-2005 07:47:18
third party image
Hey guys
put the loader on today! works better than expected! Its not as slow as i was xpecting it to be!
Just thought you might be interested! a couple of pictures below
the front frame was made up by the garage next door.
Ben
lonestarjeff
06-13-2005 21:10:44
 Re: Loader is on! in reply to ben uk, 06-11-2005 07:47:18
Great looking loader! I can't tell how it's mounted, is there a belly bracket bolted up underneath? I had to fabricate one to fit an old Ford loader to my 165. It was quite an adventure working it all out!
Jeff
ben uk
06-16-2005 12:18:56
 Re: Loader is on! in reply to lonestarjeff, 06-13-2005 21:10:44
Hi
yes it has a belly plate underneath, veritcal stands bolted to that, then another plate under the front, and diagonal cross members on either side going to the top of the vertical uprights. Certainly isnt going anywhere!
thanks for taking an interest!
Ben
DavidP, South Wales
06-12-2005 08:17:55
Hi Ben,
The loader looks very good and the bucket seems to be in very good condition. Just a couple of things to keep in mind which may be useful;
The bolts holding the stays to the pillars can work loose or snap. Make sure they are kept tight and they do not 'bottom' as they go into blind holes. Easier to remove a broken 'free' end than one which is tight. The bolts between the pillar and cross-beam also need an occasional check. The 'umbrella' handles on the bucket/fork hooks give a reasonably good life but the plates that they hook into do rust and become easily damaged.
May have mentioned it before but this loader was made by Steelfab in Cardiff for MF. A local MF dealer bought a lot of the parts and loaders when the firm closed and now has a part of the business devoted to loaders. If you need anything for it, try Ted Hopkins on 01633 680754.
Hope it works well for you.
Cheers
DavidP
Roy in UK
06-12-2005 21:22:34
 Re: Loader is on! in reply to DavidP, South Wales, 06-12-2005 08:17:55
Not forgetting those 4 bolts that actually mount the cross beam to the transmission hosing. They tend to work loose too.
ben uk
06-11-2005 07:48:24
third party image
and another one....
sibby(Aus)
06-11-2005 16:35:58
 Re: Loader is on! in reply to ben uk, 06-11-2005 07:48:24
Ben, Looks really professional, will come in real handy for a lot of chores! Well Done and cheers.
