135 lifts
Mark
04-27-2000 11:45:10
Does anyone know any shortcuts or quick fixes for a slow lift? Mine is a little slow and I have heard about some type of filter underneath the seat i could check?
Bob
04-30-2000 18:29:21
 Re: 135 lifts in reply to Mark, 04-27-2000 11:45:10
The filter is on the pump, in the bottom of the rear housing. You really need the service manual. I strongly suggest you obtain one. You need to drain the rear end, center and trans, then remove the PTO lever cover, you can see the filter from here. The system almost certainly has water in it from condensation and rain leaks. Complete draining and refilling with high quality new tractor diff/hyd oil is the only thing to do. The filter is also likely damaged by the water. New filters are available from several sources.
Good luck,
Bob
Don H
05-01-2000 13:09:30
 Re: Re: 135 lifts in reply to Bob, 04-30-2000 18:29:21
I have a 1976 MF 130. What about the filter on it? It lifts OK when cold, but settles. It lifts much slower when hot. Thanks
130
05-02-2000 21:55:25
 Re: Re: Re: 135 lifts in reply to Don H, 05-01-2000 13:09:30
Better look at your piston, sounds like it needs new rings.
