Adding Auxilliary Hydralics to a MF 135
Christos
06-24-2005 11:24:52
Hi all, I know this has been discussed in the past, but how, and what do I need to add hydraulic ports to my tractor? I know there is a little box that mounts on to where the pressure port is and has a little lever on it that you can set back and forth between the add ons and the three point. Do I have to buy that box? Can I use the pressure port instead? How much will this cost, and I can I use a 3-point JD No. 9 Sickle Bar mower that might use a cylinder on my 135?
I thank you all for your assistance!
Christos
alan in uk
06-26-2005 12:38:34
 Re: Adding Auxilliary Hydralics to a MF 135 in reply to Christos, 06-24-2005 11:24:52
okay you can add ports on to your tractor easily,just plumb a line into the pressure port, opperate the linkage lift control and once the linkage reaches full hieght (constant pumping) you will have aux pressure, ideal for tipping a trailer etc, but if you want to use a mounted mower, You will deffinatly need to get that change over block.
The change over block will lock the 3point linkage in a set position, and direct oil flow to your cylider on your mower!! (or to a spool block)
Sorry can't help with a price!
take care Alan in the uk
