Massey ferguson model 50
Andy Stoelting
07-23-2005 20:43:10
i have a early 1960's massey ferguson model 50 deisel tractor which I am haveing problems with the transmission. I have had several incidences where the transmission will lock up and will not allow the gear shift to be moved without pulling the cover plate off and manually shifting the gears internally. Is there something else I can do to get the gears unlocked without taking the transmission apart?
Big Dean
07-24-2005 19:26:10
 Re: Massey ferguson model 50 in reply to Andy Stoelting, 07-23-2005 20:43:10
Hi Andy Here is an artcile I wrote on that problem it tells what causes the problem how to prevent it from happening and how to get the lever unstuck through the filler plug hole. If I can be of furthet Enail me
Cause for Shift lever hang up
The transmission main shaft lever hanging up is very common on most models of the MF tractors. The shift lever is held down by a spring & when you start to shift it you will unconsciously lift upon the lever. This causes the shift lever to go into the other shift fork on the other shift rail. That rail can not be moved because of the lock on the back of the transmission to prevent it from going into two gears at the same time. Once you have both shift rails in the neutral position you can then move the shift lever.If you will use the palm of your hand When changing gears to push the lever into neutral then get hold of the lever to put it in the gear you want it in. Shifting it that way it will not hang on you again. Below is the article from my web site that tells how to get the lever unhung. If I can be of further help Email me at daustin62@aol.com.
Getting the main shift lever unstuck
Pull your filler plug for the transmission look inside you will see a big gear. Find a level spot shut off the tractor. Push the clutch down & put the high low shifter in neutral to relieve any pressure that might be on the gears. With a long screwdriver or a small pry bar pry the big gear forward if it is hung in reverse pry it back if it is hung in first gear. If you happen to go to far it will go in the other gear. If humg in second or third gear you have to pry on the shift fork you can see through the filler hole. if hung in second pry the fork toward the front of the tractor. If hung in third pry the fork toward the back of the tractor. You need to get it in the center. You should be able to feel the detent balls pop in the grooves in the shift rail as you move the gear. Through the years I have probably unstuck at least a 1000 of them this way. It is a common problem on the Massey tractors after they get a little wear on them
TRC
07-24-2005 12:06:41
I have a MF135 and have had a similar problem. From the postings I've seen, it's a common issue on these tractors due to wear on the shifter.
Query past postings on this forum for advice, (there are a lot of these postings out there) but simply using your palm to shift out of gear will help tremendously. We pull up on the shifter without thinking, accidentally causing the shifter to lock.
On my 135 I was able to pull the transmission filler plug and use a large screwdriver to push the large gear back into place.
