MF135 PTO Brake
BillWV
07-29-2005 09:44:26
YTers,
How big a job is it to fix the PTO brake on a 135? I"m assuming its just worn out friction material.
Thanks,
Bill
Big Dean
07-29-2005 13:46:05
 Re: MF135 PTO Brake in reply to BillWV, 07-29-2005 09:44:26
On an MF135 with Independent PTO to replace the PTO holding brake you have to remove the liftcover. Before you remove the liftcover you have to remove the access plate with the dipstick and response lever in it. Inside you will see 2 small levers sticking up with a roller between them they have to be sprung apart just enough you can remove that roller from between them before you lift on the liftcover.
