1250 m. f
Bruce
05-01-2000 15:00:59
I have a 1250 compact ..... real good tractor ! but it started a makeing a noise in 4 wheel dr. mostly in reverse... any ideas what this could be ? I use this in my work every day so Help if you can..... . Thanks Bruce
Ray
05-03-2000 09:06:57
 Re: 1250 m. f in reply to Bruce, 05-01-2000 15:00:59
I own a 1040 (mid 80s two generations ago) 4wd compact with a loader. It makes a noise, sort of a whining/howling sound when the front end is under severe load. In these circumstances I disengage the front end and when I do so, the lever is hard to move which is further evidence of the strain. When I have a loaded bucket with no rear ballast, I can lift the rear wheels by engaging the clutch too aggressively in reverse. This is obviously not good for the machine and shows how much load can be put on the front drive train which was only designed as an assisting device. There is no substitute for proper ballast. The rear drive train of my 1040 can handle quite a bit. When properly ballasted I can back out of anything except for extremely slippery (mud or ice) steep grades. The rest of the time 2wd is all required.
Verify lubricant level first. If it howls under no load and it did not before, there may be excessive wear but you may want to wait for a few more suggestions before spending too much. If the sound gets worse or is more of a grind or something else, it may require real and more immediate attention.
Good luck and I'm sorry that I cannot give a more definite diagnostic.
Ray
