MF135 NOT CHARGING
BigMarv1085
08-04-2005 06:15:23
My 135 will not charge the battery. I had the alternator tested (checked good) nad have a new battery. All wires and connections look good. Suspect it might be the voltage regulator. If so, how would you test it.
Big Dean
08-04-2005 20:04:18
 Re: MF135 NOT CHARGING in reply to BigMarv1085, 08-04-2005 06:15:23
Run a jumper wire from the positive battery post to the F or field terminal of the alternator if it a full charge on the ammeter your alternator is good just run it long enough to check it.Running it that way for more than a few minutes will burn up the alternator and the battery. It is not uncommon for the terminal on the voltage regulator plug to corroded on those not make contact causing them not to charge.
supergrumpy
08-04-2005 07:48:43
don"t know what year you have but my 1970 has one of those 1 wire delco alternators with regulator inside the alt, very simple and works like a champ
lots of posts about the conversion in the archives, pick em up cheap in wrecking yards or neighbors yard
