Massey Harris pto
Bill Jones
08-14-2005 19:28:50
How hard of a job would it be to add a pto to a massey harris 22 that has a plate in the rear section of the crank case? Thanks
Steadman
08-21-2005 16:01:55
 Re: Massey Harris pto in reply to Bill Jones, 08-14-2005 19:28:50
Bill, I took one out of my MH81. Basically the same thing. There should be a roller chain around the shaft that does nothing but idle around & splash up oil to the shaft. This will prevent you from just sliding it in the hole where the plate is now. I had to take off the top plate to see what was what & to deal with the roller chain. If you plan on running any equipment with this tractor, please add an override to the shaft before you use it... wouldn't want to see a fellow YT'er become a statistic. Also, some of the MH shafts were an odd size & needed an adapter. Enjoy, they're a heck of a nice little tractor. - ALAN
