Massey 1150 - more power
billybunter
08-17-2005 15:56:45
Are there any easy and cheap methods of getting some more power out of these without making them unreliable? What BHP can I expect?
Thanks for now.
Boss Hog
08-19-2005 05:19:26
 Re: Massey 1150 - more power in reply to billybunter, 08-17-2005 15:56:45
I"m with Joe - An 1150 has plenty of power if everything is adjusted right.
I"d suggest checking the following:
1. Clean air cleaner
2. Fuel injectors clean
3. Tappets adjusted correctly
After that, I think you can turn the injector up a bit. But I doubt you"ll need to.
One thing to keep in mnd - The engine neds to be turning about 2,200 RPMs to hit full power. Below 2,000 you aren"t getting all the HP you can.
JoeMN
08-18-2005 19:12:32
An 1150 short on power? What do you want to do with it? The 1150 and 1155 had tremendous power for a row crop tractor. If you aren't getting enough you better pull your socks out of the air cleaner. If you want a pulling tractor,twin turbos and more fuel will do the trick. How reliable does it have to be? 100 yards pulling a skid or hundreds of hours on the chisel plow?
