202 industrial - PS plumbed to run on loader
arainfor
09-19-2005 16:13:54
I have a 202 industrial that had a bad PS pump (dumped all the fluid into the crankcase) I can"t afford a new one for such an old tractor so I pumbed it with at T right before the loader spool. Since it"s an open circuit to the loader I don"t have any pressure to the PS spool. Any info on either what the extra port on the spool is for or the type of priority valve I need would be great. I could find a valve if I had the specs for the front mounted pump also.
Used-to-be-Iowa-Dave
09-21-2005 07:55:30
 Re: 202 industrial - PS plumbed to run on loader in reply to arainfor, 09-19-2005 16:13:54
Not positive on the spool question, but was real common for these tractors to be outfitted as a loader backhoe. I'm afraid you're going to hear crickets chirping on the rebuild issue. I've looked high and low as mine is on it's last legs.
TG IN va
09-20-2005 09:18:59
Why not get the PS pump rebuilt?
TG IN va
09-20-2005 09:18:05
arainfor
09-20-2005 11:01:35
 Re: 202 industrial - PS plumbed to run on loader in reply to TG IN va, 09-20-2005 09:18:05
I"ve never found a rebuild kit for a 544443M91 Cessna pump. I don"t see how it would be possible to rebuild with fluid leaking past the power shaft. If anyone has a line a getting it rebuild though that would be great also.
