massey pony
cam2
09-23-2005 17:34:48
i have a push plow on my pony,hyd will only lift it up half way at full thotle,hyd level is right up.is there a presure valve on the pump or valve body to crank up the presure?/
jjcomp77
09-29-2005 06:51:12
 Re: massey pony in reply to cam2, 09-23-2005 17:34:48
Check and see if your fan belt is tight enough the hydraulic runs off the fan. It may be slipping the belt.
John
Case450
09-23-2005 20:22:20
i am not familiar with the pup your talking about. I have two massey fergusons (a wheel loader and a fourwheel drive tractor) and your hydraulics shouldnt' be acting like that. If the hydraulics hold up in the air with the machine at idle or off(the blade doesn't fall down on its' own) than you have a bad hydraulic pump. wouldn't cost too much to get it rebuilt. If the blade does fall down than you have bad cylinder seals. hope that helps
