M-F front suitcase weights
Tom in Mo.
09-25-2005 14:57:56
third party image
I put some photos on the Parts and Pieces section of the photo gallery. Heres the link I hope:
Fred from NY
09-27-2005 19:56:53
 Re: M-F front suitcase weights in reply to Tom in Mo., 09-25-2005 14:57:56
These weights came both ways re:the retainer bolts. The earlier ones only had the threaded hole for the bolt. The early weights were smaller in size and painted red. Later they were increased in size and painted Massey flint metallic grey and then later Massey flint grey.
Hope this helps.
Tom in Mo.
09-25-2005 15:08:12
third party image
One more. This is after and before cleanup and priming. Any info is appreciated.
bob softness
09-26-2005 12:22:09
 Re: M-F front suitcase weights in reply to Tom in Mo., 09-25-2005 15:08:12
i have a massey. never bothered getting thr right weights. a peice if wire with somthing heavy always worked for me. it is a tractor i use for work. (235)
Don-Wi
09-26-2005 06:02:46
Those are almost exactly like the ones I was describing yesterday, except there appears to be no way to hold them on the tractor. The hole on ours for the bolt is located in the 1st angled part after the straight shot down. There is then a square notch about 1" in where the square nut is located. I"ll try to remember to take a picture when I get home.
What are you mounting them on? could make a difference as to the color, but those look like the same silver that ours are painted
Donovan from Wisconsin
Tom in Mo.
09-26-2005 17:52:45
 Re: M-F front suitcase weights in reply to Don-Wi, 09-26-2005 06:02:46
I have the weights but no Massey-Ferguson to hang them on. Seven tractors but no M-F; shame on me. I am holding out for a 97 propane built by M-M or a 98(by Oliver?) with the GM two stroke diesel. Then I'll have a machine to hang them on!
The last picture shows that they hang on a vertical bar (as on the channel iron) and bolt into the threads on the slant about 2/3 the way down. You can just see the threaded hole with a dauber nest in it.
Lou
09-26-2005 06:31:15
Don, They hang on a flat piece of steel on the front of most Masseys. Im not sure if your supposed to bolt them together? Lou
Don-Wi
09-26-2005 06:44:54
 Re: M-F front suitcase weights in reply to Lou, 09-26-2005 06:31:15
You don't bolt the weights together, there is a bolt w/ a big, thick square washer that holds them onto that plate.
We used to have 4 of those on our 285 w/ a large chunk of concrete w/ a pipe through it hung between them. We took it off because we don't need the weight anymore, but we still have it around "just incase". Now we just have the 5 weights on to keep the front from bouncing too much
Lou
09-26-2005 07:25:49
 Re: M-F front suitcase weights in reply to Don-Wi, 09-26-2005 06:44:54
Don , I recently found 3 weights for my 175, it needed weight often. Ive just got them hanging from the bar. sounds like I better check into this bolt your refering to so they dont come off.
Don-Wi
09-26-2005 20:53:24
 Re: M-F front suitcase weights in reply to Lou, 09-26-2005 07:25:49
third party image
Here's a shot of the washer that is under there. It's atleats a 1/4" thick, anything less will bend. I know this because one of our weights was missing the bolt and everything, but we had a few thinner square washers around that were the same size. It bent, but after a while it finally held. It's in the middle now so it won't go anywhere.
Tom in Mo.
09-27-2005 16:59:28
 Re: M-F front suitcase weights in reply to Don-Wi, 09-26-2005 20:53:24
Mine do not have that opening for the big square nut. Mine are just threaded at the same place on the slanted section. Thanks for all the info.
Lou
09-27-2005 14:07:12
Thanks for that picture Donavan,,Lou
Don-Wi
09-26-2005 20:49:32
third party image
Here's a picture of the weights on our 285. I'll post another of how they mount.
Don-Wi
Tom in Mo.
09-25-2005 15:05:29
third party image
Here's another. Anyone know the paint codes for these? I beleive they were originally the light gray or silver.
Roy in UK
09-25-2005 23:00:45
 Re: M-F front suitcase weights in reply to Tom in Mo., 09-25-2005 15:05:29
Just to confuse matters, the MF 1100 we had came with 8 front weights identical to those pictured, as standard equipment. They were painted red.
Tom in Mo.
09-25-2005 15:01:03
third party image
Try again.
Marrty G.
09-28-2005 04:46:03
 Re: M-F front suitcase weights in reply to Tom in Mo., 09-25-2005 15:01:03
How much do these weights on average?
