235 starting problem
chuck t
09-29-2005 17:06:15
we have a 235 that will occasionally not start. Turn key. nothing. Won't pop start. Push/tow it a bit and it may start quickly, may not. Do it long enough and it will start. Checked the usual culprits. May be ignition switch, but is there a switch/sensor on the tranny we can check? It almost seems like it does not sense that the tranny is in neutral
Big Dean
09-29-2005 18:20:23
 Re: 235 starting problem in reply to chuck t, 09-29-2005 17:06:15
There is a neutral safety switch on the top of the transmission bellhousing straight forward from the short two speed shift lever. it should have a rubber boot on it with two wires coming from it.That lever has to be in neutral for it to start. the wires will sometimes not make contact where they plug in to the switch.
