Massey - Harris 101 JR
Arthur
10-03-2005 06:44:19
Morning Everyone I'm looking into buying a 101 JR, and was wondering how to tell the size of the engine, as I here it could have come w/ 3 diffrent size's...Thanks Art
parts man
10-03-2005 16:22:35
 Re: Massey - Harris 101 JR in reply to Arthur, 10-03-2005 06:44:19
The engine serial# tag will say engine size.
Arthur
10-04-2005 03:29:56
 Re: Massey - Harris 101 JR in reply to parts man, 10-03-2005 16:22:35
Thanks...I talked to the guy last night, and he though it is a '46'...which means it has(or should have) the larger engine in it.Do you know anything about these tractors? what are the weak points, as well as the better points?
Alberta Mike
10-04-2005 06:59:53
 Re: Massey - Harris 101 JR in reply to Arthur, 10-04-2005 03:29:56
What is the serial number on your tractor? I have a reference here for both row crop and then standard models that tells you what engine (124, 140, or 162)was originally in your tractor when it came off the line. Being a '46 I would guess it was the 162 because that was probably the last year the 101's were made. You'd have to assume of course that the original engine is in the tractor to use this information. Post your tractor serial number here (and it's front axle configuration) and I'll get the information from you.
Arthur
10-04-2005 09:12:17
 Re: Massey - Harris 101 JR in reply to Alberta Mike, 10-04-2005 06:59:53
I should get over there towards the end of the week....I'll have to get back to you on that....Thanks
Alberta Mike
10-04-2005 13:50:42
 Re: Massey - Harris 101 JR in reply to Arthur, 10-04-2005 09:12:17
If the oval tin plate on the left side of the transmission cast housing is missing, the serial number is also hand-stamped into the upper machined surface of the transmission, specifically on the left upper surface between the shift lever platform and the metal lid on the differential area (near the foot clutch resting location). It might not be stamped too deeply so you might have to scrape and wire brush away crud, etc to find it, but it will be there.
