101 JR greasy brakes
101jrWebbervill
10-03-2005 07:58:07
When I removed the plate that contains the brake drum this was full of grease and gear lub. The shoes are shot, so I need to have them relined, is there supposed to be grease in there? There was a lot of grease in there.
I know for sure my axel seals are leaking, does anyone know where I can get a set of seals for a 41 101JR?
ennismore.mike
10-04-2005 05:22:28
 Re: 101 JR greasy brakes in reply to 101jrWebberville , 10-03-2005 07:58:07
Same seal used on both Junior & Senior. Massey part no. is 14318x. 2.750 x 3.876 x .375. National - Federal Mogal # 415960. Check old seal, I used this seal on my tractors.
101jrWebberville
10-04-2005 11:34:24
 Re: 101 JR greasy brakes in reply to ennismore.mike, 10-04-2005 05:22:28
Regarding the first part of my question, do the 101JR have "wet" brakes or is the grease in there because the axel seals are leaking.
Thanks for the info about the seals, this will help alot
ennismore.mike
10-04-2005 13:51:00
 Re: 101 JR greasy brakes in reply to 101jrWebberville , 10-04-2005 11:34:24
Should be dry. Check for drain hole.
Dave_Id
10-03-2005 09:41:16
Take whatever seal you have left after removal, or get a number off it. Or write down the dimensions, ID and OD, take to any bearing and seal distributer, and they'll get the seals for you
