MH 44-6 Transmission stuck in gear
Brian Kaldunski
10-04-2005 11:01:45
On my 44-6 thier is a spot in the transmission between R and 2 that if you hit it with while shifts into 2, out of third, or into reverse it will get stuck thier, it is second gear but it isn"t in second gear. It happened to me twice before but i poped the clutch and it came out. This time it is in thier good. I am wonder how to get it out. the only thing is that would have to take the top of the transmission off. Is their anyother idea"s on how to get it unstuck???
masseydiesel33
10-06-2005 08:52:01
 Re: MH 44-6 Transmission stuck in gear in reply to Brian Kaldunski, 10-04-2005 11:01:45
When my 33 gets stuck in gear i take the cover off the slide rails next to the imput shaft of the transmission, take out the two bolts and you will have access to the three shafts and should be able to move one to get it loose and it only takes a few minuites to do instead of taking the covers off the trans. hope that it helps it has worked for me.
w anglemyer
10-04-2005 17:19:27
PULL THE SHIFT LEVER OUT LOOK DOWN IN AND LINE THE SHIFT RAILS BACK UP YOUR SHIFT LEVER IS WORE
msb
10-04-2005 19:13:38
 Re: MH 44-6 Transmission stuck in gear in reply to w anglemyer, 10-04-2005 17:19:27
And while you have the shifter out, braze it back to a normal shape.
Brian Kaldunski
10-06-2005 11:22:51
 Re: MH 44-6 Transmission stuck in gear in reply to msb, 10-04-2005 19:13:38
How hard is it to take the shifter out and is it fairly obvious what shape it should be.
