101 Junior/continental F140 no power
101JRWebberville
10-10-2005 11:39:49
I recently purchased a 1941 101 Junior with a continental F140. The tractor is having some issues running. Any time the tractor is under any strain it stalls. Stain meaning going up a slight hill, or having more then 2 people sit on the tractor. This was running in 3rd gear. If you go into any other gear it stalls right away. The tractor is still a 6 volt system, the generator is not hooked up and it has a 12 volt battery installed. Oil pressure is at 35 (I believe) can check this tonight if needed. My father suggested that the issue was the distributor is not advancing since there is a 12 volt battery installed. This is our first tractor and don’t know much about them. Does anyone else agree this may be the issue, or is there something else I should be looking into? Possibly a bad governor?
Also I am looking to convert to a 12 volt system and also would like to get rid of the points. I would like to get a kit to do this because they usually come with a bracket for the alternator, I don’t feel confident I could make one that would work well. Does anyone know of a good kit?
Dr Chris
10-10-2005 20:11:21
 Re: 101 Junior/continental F140 no power in reply to 101JRWebberville, 10-10-2005 11:39:49
I would guess your main jet in the carb is clogged. If the engine will rev up fine with no load it's not the distributor, if it was it would pop and backfire. You are supposed to oil the distributor every so often. Buy, a operators manual, lots of info. If its bogging down it's your carb. If it's still 6volt and you have a 12volt battery you need to change the coil to 12volts. That could be why it's stalling. Also this tractor is 6 volt positive ground, so it's not like a car.
