clutch on 265 massy
cannonball
10-11-2005 07:51:06
had massy 265 brought to me, someone had put in clutch without using clutch setup tool..will not release...is there a way to set this without breaking it apart or do i need to split it..if i split it can someone tell the distance the fingers need to be, i don't have tool for setting clutch..use to working on john deere's...thanks have nice day may god bless
Big Dean
10-11-2005 09:43:03
 Re: clutch on 265 massy in reply to cannonball, 10-11-2005 07:51:06
If the clutches were not lined up and someone pull it together with bolts they most likely warped the disc if so I doubt it can be adjusted to where it will release I have a picture that shows how to adjust the two stage clutch and one that shows how to build a lineup tool and how to set the release finger height without the tools. If you will send me an email address I will send those picture to you.
