135 Serial Number
135
10-22-2005 11:12:06
Where is the serial number on a MF 135 because my 135 has the serial number plate on the dash missing. Also where is the engine number for a Perkins 3.152 diesel engine?
BOB UK
10-27-2005 11:32:35
 Re: 135 Serial Number in reply to 135, 10-22-2005 11:12:06
If it's just the age you are after, on the early Perkings engines a casting date for the engine can be found on the bottom front of the engine if you slide under the tractor it can be seen on a flat angled part near the sump.
hope this is of help
Bob
England
Glen in TX
10-24-2005 16:20:05
Unfortunately for you the tractor serial number was on that tag that was once on the dash. Engine serial # is on left side of block. Trans # is on top right hand side. Rear Axle # is on top left hand side. MF-135 made 1964-75.
