1085 hydraulics
BigMarv1085 in
10-25-2005 06:04:53
When I start up my 1085, the remotes hyd.s are extremley slow to operate. Once the tractor has warmed up, they work fine. I replaced the aux. pump and pto clutches last year. What could be the problem.
Big Dean
10-25-2005 08:21:57
 Re: 1085 hydraulics in reply to BigMarv1085 in Ga., 10-25-2005 06:04:53
There is a tube with O-ring on each end it is about an inch or so long it goes between the filter and the auxiliary pump. If it is slid a little to far forward or backwards it will let the auxiliary pump suck air. Once the oil get to the pump it will seal off and it will work till the pump looses it prime then it takes a while for it to pick up the oil again. I have had that happen on several tractors. Sometimes they will not pick up the oil at all if the slip to far. My guess is that is what is causing your problem.
BigMarv1085 in Ga.
10-26-2005 06:28:24
 Re: 1085 hydraulics in reply to Big Dean, 10-25-2005 08:21:57
I'm familiar with this tube and do remember centering it between the filter housing and pump with new o'rings. Maybe it won't get any worse.
