Hi there, many many years since I posted in here.Now, well, I have a MF 50 Industrial (UK built) with a problem (among other problems). The transmission makes a noise in forward. When I press the right side of the trottle to engage the forward clutch it makes this noise. If I press the left side of the trottle it makes no noise at all. The sound of the noise is like an axle is spinning very fast, or a gear is spinning very fast, with a totally worn out ballbearing. And, it sounds like the speed of the axle / gear / bearing is very high. And as I say, not when I drive backwards. Sometimes a similar noise comes when the engine is just idling and none of the clutches are engaged. Sometimes I can even engage the forward clutch and no sound comes, not until the engine speed gets up to between 800 and 1200 rpm, and then the screaming noise comes back. A guy I talked to here in Norway said it was a loose vane in the torque converter, but that sounds odd to me as it has it only when I move forward. Anyone who has an idea about this ? I perfectly understand I have to split the tractor.. yuck what a job with loader and cab... Yeah, I guess I need to mention that I have replaced the oil... which was dark brown and smelly. That indicated worn out clutches, but the tractor moves just fine both ways. Bill in Norway.
