Hydraulic problem on MF175
69zfarmer
10-27-2005 17:41:25
I have a selector valve under my seat to swap from 3point hitch to remotes.I have my loader which has its own valve tied into the quick connect remotes I have to tie back lever on remotes and then i use my loader valve to operate the loader.It (the loader) has quit working i can select the three point hitch and it works fine.I took the selector block off and checked o-rings and replaced all of them (including both ends of stand pipe)still not working.Could it be my remote valve bad that i have tied back causing the problem? I checked my loader valve it is not the problem.
69zfarmer
10-30-2005 05:58:32
 Re: Hydraulic problem on MF175 in reply to 69zfarmer, 10-27-2005 17:41:25
Thanks Big Dean for refreshing my memory that fixed it.
Big Dean
10-28-2005 05:08:35
You did not say if the three point would raise with nothing on it or if it will lift with a load. A couple of things to check when you switch to the remotes are you putting the position control in constant pumping. Check to be sure the quick couplers are plugged in good.
