Headlights
BrentO
10-29-2005 16:21:38
I have an FE-35 with a cylinder Perkins. Today I was trying to remove the original headlight buckets to clean, paint and re-wire them, could someone tell me if the flat headed bolts with the sqaure backs that hold the lights on are avalable ? They are spinning and I can not hold the heads of them, before I get the hot wrench out I want to make sure I can get new ones.
Thanks
Brent
Willy-N
10-30-2005 17:48:10
 Re: Headlights in reply to BrentO, 10-29-2005 16:21:38
I have befor ground the nut with a grinder to the threads and removed them from the bolt. After there off cleaned up the threads real good and used new nuts on them. I hate to wrench the buckets hard since once messed up there big bucks to replace!! I never try much more than a little liquid wrench and some ft pounds, then out comes the grinder messed up a few head lights befor so I quit while I am ahead now. Course that requires removing the hood to get to the nut but you would have to do the same to torch them off! Mark H.
Willy-N
10-30-2005 17:48:06
Willy-N
10-30-2005 17:47:25
DavidP, South Wales
10-30-2005 08:10:09
Hi
These bolts are a real pain in the****. You can't hold them and the slightest damage will prevent the nut moving freely..... if you get it off to start.
Certainly in the UK as far as I am aware, replacements are not available. Try and persevere working the nut back and forth using a 'maintenance spray' of some sort. In desperation a little heat should be OK. Use a small gas cylinder blow torch if you can rather than the excessive heat of oxy-acetylene. Let it cool to cold and try again. Be patient it may take a while but we have not failed yet.
Good luck
DavidP
krm
10-30-2005 07:51:56
Make sure it is the bolts and not the buckets that are wore out.
