need fuel cut solenoid MF135
BigBoyinMS
11-06-2005 08:58:05
I have a '73 MF135 Perkins 3-cyl gas that I need a fuel cut solenoid for. Used or new as long as it works. I just can't get over the local dealer wanting $73 for what should be a $20 part. What's new, eh?
Anyone out there got one? Or another source that's less expensive than mine?
If I have to I'll run it as is. The previous owner snipped off the tip so the tractor would run and it doesn"t run-on too much when I kill it.
Thanks!
supergrumpy
11-07-2005 11:10:01
 Re: need fuel cut solenoid MF135 in reply to BigBoyinMS, 11-06-2005 08:58:05
save your cash for the tuneup
just before you shut down, idle the engine and put trans in 3-high range, stomp on brakes
as engine almost dies, let the clutch out and engine STOPS
I add 1/2 tank of plus grade gas every now and then, give the gal a treat and stops the run on for a while
