Putting Hydraulic remotes on a MF 135
Christos
11-10-2005 06:40:02
Hi all, How does one go about adding remotes to a 135? I've seen three different ways - one that uses the pressure port, a diverter valve that has two joysticks and and little box that mounts where the pressure port goes and there is another box that has the lever that actuates it.
I think my 135 has the 4gpm pump in order to pull this off would I have to replace it with the 9gpm pump?
Thanks,
Christos
DavidP, South Wales
11-10-2005 10:33:56
 Re: Putting Hydraulic remotes on a MF 135 in reply to Christos, 11-10-2005 06:40:02
Hi,
Putting remotes on is straight forward. Largely it depends on what you want to do with them. If you are only operating rear mounted equipment eg tipping trailer then a simple divertor valve will do. If you have a front end loader you will need a valve with two outlets to be able to change over. As to fitting a high capacity pump set up, again it's down to what you want to do. The Ferguson pump will remain in place and you add another pump to increase flow. With the Ferguson pump you have a max pressure of 2350 to 2500 psi. Normally the combined set up only has around 2000psi available as the relief valve on the new pump will blow first. It is not adjustable. The cost would be considerable and unless you plan to do a lot of loader work for example where you actually 'waiting' for the loader to lift each time the standard pump should be quite adequate.
Regards
David
