m35 clutch
butch tn
11-24-2005 03:59:02
HOW BIG A JOB IS IT TO REPLACE THE CLUTCH? MY PROBLEM IS THAT I HAVE ADJ THE CLUTCH BUT SOME TIME IT STAYS ENGAGED SHOULD I ORDER THE WHOLE ASSY OR WAIT UNTIL I TEAR IT DOWN?
THANKS
DavidP, South Wales
11-24-2005 12:59:02
 Re: m35 clutch in reply to butch tn, 11-24-2005 03:59:02
Hi,
It's possible that if the clutch stays in engagement that it is nothing more than the splines on the main plate dry or rusty. Will the tractor actually drive with the clutch pedal down or is it just difficult to get in and out of gear?
Don't buy parts yet.
Regards
DavidP
butch tn
11-25-2005 03:04:17
 Re: m35 clutch in reply to DavidP, South Wales, 11-24-2005 12:59:02
WHAT IT DOES IS THIS WHEN YOU ENGAGE THE CLUTCH ALL THE WAY DOWN THE TRACTOR WILL KEEP MOVING AS SOON AS I HIT THE BRAKES IT STOPS,IT AT TIMES IS HARD TO GET IT IN GEAR
THANKS
BUTCH
DavidP, South Wales
11-25-2005 11:43:38
 Re: m35 clutch in reply to butch tn, 11-25-2005 03:04:17
Hi again,
From what you say in your reply gives me another possibility. Are you losing any oil from the split pin under the clutch housing? It is possible that there is some oil present on the clutch plate making the surface 'sticky'. This is often enough to prevent the clutch disengaging until a greater load (brakes) are applied. This would also account for difficulty in engaging gear. Do you have correct pedal movement? In normal times, was the forward motion stopped before the pedal reached the second stage of the travel?
Regards
DavidP
butch tn
11-29-2005 04:46:54
 Re: m35 clutch in reply to DavidP, South Wales, 11-25-2005 11:43:38
most of the time when i get it going for a while its inttermittent.i dont think this has a 2 stage clutch mit be wrong
thanks butch
supergrumpy
11-25-2005 09:17:15
do not know your situation
if tractor has been worked hard and this gradually got worse, thats a lot different than a tractor that sat a long time or only gets very light use
there are some similar posts with good comments in the archives here, a search should bring them up for you
possible rust or friction material built-up on flywheel/pressure plate, splitting might be last thing you try
