MH gauges
Ben Massey
11-27-2005 08:23:49
It is my understanding that Stewart Warner supplied gauges for MH tractors. If that is correct where could I find a replacement set of S.W's.?
Thanks,
Ben
Alberta Mike
11-28-2005 06:35:35
 Re: MH gauges in reply to Ben Massey, 11-27-2005 08:23:49
Maybe I'm wrong but I don't ever remember seeing any gauges with Massey Harris on them (if that's what you're looking for). Most of the original gauges I've seen on stuff from the 40's were made by Rochester in the USA. Very small lettering at the bottom of the gauge ID'd the manufacturer.
Jason(PA)
11-27-2005 14:00:55
To my knowledge no one makes original looking gauges for MH tractors. Maybe someone started. Do a search on Stewart Warner or see if you can find a phone number. I hope someone does start making them. They are about the only ones that arn't reproduced.
Harris Guy
11-27-2005 16:49:45
 Re: MH gauges in reply to Jason(PA), 11-27-2005 14:00:55
The reproductions by Faria Corp. Uncasville,CT are
near identical to the originals. Probably have to go through some supply house to purchase one or three.
Lloyd
11-27-2005 16:13:42
Greg Anderson 31414 125th Str. Princeton Mn. 55371 763-389-4275 Replacement gauges like originals $105 for set of three.
Click on Parts and Pieces then type 444 in the search bar if you would like to look at some before you buy. Good luck
Ben Massey
11-27-2005 17:31:05
 Re: MH gauges in reply to Lloyd, 11-27-2005 16:13:42
Thanks for the info gentlemen!!
Ben Massey
11-27-2005 17:30:09
