HI/LO Beam Headlamp
Bill Darte
12-07-2005 12:43:06
On a hi/lo beam...3 terminal headlamp, which is ground? Is it the central lug which points 90 degrees out from the line of the other 2? That would make sense to me, but who knows...
Thanks and have great holidays....
jerrycpp
12-07-2005 15:16:38
 Re: HI/LO Beam Headlamp in reply to Bill Darte, 12-07-2005 12:43:06
If my memory is correct, you're right. You can test it with an ohmeter - current should flow from either of the two to the single odd one. You can also run a jumper wire - the only time the bulb will light is when you have a + and a - connected. You can also figure out which is high and which is low that way.
AllanC
12-11-2005 20:09:38
 Re: HI/LO Beam Headlamp in reply to jerrycpp, 12-07-2005 15:16:38
If memory serves... it's one of the side ones.
