old weather starting
Big Dean
12-08-2005 10:10:32
Just a reminder with the cold weather here those old diesels get a little hard to start. The Perkins engine do not handle starting fluid well. It only takes a little to much one time to bust the ring lands off the piston. A block heater plugged in 3 or 4 hours before you need the tractors is a much better way to start then in cold weather.
jerrycpp
12-08-2005 12:52:08
 Re: old weather starting in reply to Big Dean, 12-08-2005 10:10:32
Big Dean is right on, as usual. If you feel you must use starting fluid, be absolutely sure you use only PREMIUM fluid. The cheap stuff will explode rather than burn, and that's where you get the broken rings. NAPA had #7200 in their Mac's line years ago - I don't know if they still have it or not, but find the good stuff or suffer major consequences.
GaryF
12-08-2005 12:25:32
Good subject Big Dean. Do you or any one else know where you could get plans for or buy the complete Therma-Start system for the 3 and 4 cyl perkins? So far I can only locate the heater/nozzle
Gary
Big Dean
12-08-2005 13:10:29
 Re: old weather starting in reply to GaryF, 12-08-2005 12:25:32
Gary BareCo has the bleed off reservoir in the fuel system in the fuel injection section. they have the manifold heater nozzle in electrical in switches and wiring. They don't show the lines I always used brake lines and made the lines myself.
GaryF
12-09-2005 05:10:48
 Re: old weather starting in reply to Big Dean , 12-08-2005 13:10:29
Thank you Big Dean. You have come thru for me again! I have seen a couple of older MF's with this system installed and it worked perfect.
Big Dean
12-09-2005 06:48:51
 Re: cold weather starting in reply to GaryF, 12-09-2005 05:10:48
Gary they do work very well if they are connected right. They are not as good as a block heater but if you your tractor is not close to a plug in they are the next best thing. I have a drawing showing how the lines connect to the bleed off reservoir if you would like to have it send me an email address and I will send it to you. Big Dean
