MF 202 Losing Power
Bob Lightle
06-01-2000 06:16:26
I have a MF 202. It loses power after an hour of mowing heavy grass with a bush hog. If I turn the PTO off it runs OK. The water temp is not overheating. I have had the carb rebuilt, new points and a new distributor.
Gregg
06-01-2000 20:08:18
 Re: MF 202 Losing Power in reply to Bob Lightle, 06-01-2000 06:16:26
The valve adjustment could be causing your problem, as the engine gets hot the metal in the valves, pushrods,rockers,expand and the clearence goes to the point of holding the valve off the seat,when it cools off things go back to normal if the valve dont burn out in the meantime,the seats tend to where out also,set the valves and see if it is ok, this should be done once in a while anyway, good luck! Gregg
E.Allison
06-01-2000 10:45:21
Hello, Is it missing when it gets hot? Sorta sounds like an ignition coil. Coils often work fine when cold but fail when hot. After the engine cools all is well again. I had this happen to my Ferguson TO 30. Regards, EEA
