MF135 dash question
Alberta Mike
12-14-2005 09:04:59
My friend has a '69 MF135 gas tractor. On the outside right and left side of the dashboard tin, there is a raised circular area with two holes drilled through the sheet metal. It appears as if some sort of emblem would go there but we can't tell from any photos what belongs there. Can anyone help out as to what is supposed to be mounted there?
Bill Darte
12-14-2005 12:41:49
 Re: MF135 dash question in reply to Alberta Mike, 12-14-2005 09:04:59
If it the 'far' outside and the circular areas you refer to are roughly 4-5 inches in diameter, they are for an emblem that simply reads... 135...
Looks a lot like the 174 picture at...
http://www.bareco.com.au/files/massey2001/mf76.htm
DavidP, South Wales
12-14-2005 11:05:12
Hi,
Are you referring to the instrument panel face or the outside near where the screws holding the bonnet enter.
If the holes are near the screws. one above the other, this is normally for a mirror. Normally it would be RHS for the UK and LHS for people who drive on the 'wrong' side of the road. Only joking!
DavidP
