MF 35 3 cyl 20-30 turns to start
BarryM
12-15-2005 09:29:27
Hi,
I had a Massey 35 3 cyl (1960/62?) for 25 years - always started after a few engine turns (till liner pulled! :( ). Just bought same model 1961 ("restored" condition) Serial Number SNM235026.
This tractor apparently needs "heat" to start (never did with my first tractor) but even after 30 secs heat (the plug is warm) and 20+ turns it struggles to start and the battery is taking a real caning. I get clouds of white diesel vapour - and I mean CLOUDS - and just before the battery gives up it starts with a burst of black smoke and then everything is normal. When warm it starts ok. When running it is smokeless.
Can any kind person suggest where all this diesel vapour is coming from and why the engine should be so reluctant to start?
I turn the key left to the heat position and then right to start. I also noticed that it is possible to turn the key left of the heat position and this also turns the engine. Does it matter which way its turned?
At the moment I daren't go too far away from a battery charger!
Rod in Smiths Falls, ON,
12-15-2005 13:56:59
 Re: MF 35 3 cyl 20-30 turns to start in reply to BarryM, 12-15-2005 09:29:27
To start with the thermostart you turn the key all the way to the left after allowing a sensible warmup period. My manual suggests fifteen seconds, and I find that works fine on my '61. In sub-zero (F) weather I additionally plug it in (a conventional block heater) for about fifteen minutes.
BarryM
12-15-2005 14:42:20
 Re: MF 35 3 cyl 20-30 turns to start in reply to Rod in Smiths Falls, ON, , 12-15-2005 13:56:59
Hi Rod,
Thanks for that - its a very useful piece of information - as a tractor novice (despite having a MF35 for 25 years - thats how good they are) I have been turning the key clockwise after turning it to the heat position. I dont know if that is the reason for the bad starting but I'll try anticlockwise tomorrow. I need to solve this - the amount of white diesel smoke coming from the exhaust is so incredible I have to stop because I can only hold my breath for so long!
DavidP, South Wales
12-15-2005 10:11:25
Hi,
The fact that your heater is warming does not mean that it is working. The white smoke being produced is normally excess fuel which enters the engine and leaves only partially burnt.
It's quite likely that the thermostart (heater) is constantly leaking fuel into the inlet manifold.
When the tractor is cold remove the fuel pipe, you will loose about an egg cup of fuel. Remove the thermostart. After the engine has run normally the coiled element in the thermostart will be blackish but it should be dry. Any evidence of wetness means that the thermostart has failed.
Irrespective of the engine condition I would be a little concerned and think that there are other problems, compression and fuel injection being the main two. You mention that the cranking speed is OK at the start, please check the thermostart first.
Regards
DavidP
BarryM
12-15-2005 10:38:54
 Re: MF 35 3 cyl 20-30 turns to start in reply to DavidP, South Wales, 12-15-2005 10:11:25
David - I'm ever so grateful for your suggestion. I've just been out to look at this "thermostat" (which I never used with my old MF35 - is it recommended to use this?) and I notice it is very wet around the plug - it may just be a weeping inlet joint.
If I understand you correctly I should:
1. Take the tractor for a run
2. Switch the engine off and let it get cold
3. Remove the thermostat
4. If its wet - a problem - new thermostat.
5. If its dry - I've got another problem!
The tractor is a full restoration job (not mine)with only 100 hrs on the clock so I hope its not compression problems.
Its dark now - I'll do your test tomorrow.
Many thanks.
DavidP,South Wales
12-16-2005 13:01:36
 Re: MF 35 3 cyl 20-30 turns to start in reply to BarryM, 12-15-2005 10:38:54
Hi,
That should show it. Something that you could also try is to remove the thermostart and reconnect the pipe. Secure it on a cord. Place a piece of rag or similar in the inlet manifold hole, something that can't be sucked in and run the engine. If you see any sign of a drip then thats at least one problem identified.
DavidP
BarryM
12-16-2005 14:18:01
 Re: MF 35 3 cyl 20-30 turns to start in reply to DavidP,South Wales, 12-16-2005 13:01:36
David,
I thank you again - work has just stopped me getting at this problem but I will post a reply with the results when I've done the tests. One impression I got was that the problem is much worse if the engine is not set to idle before starting - but I can't confirm this yet.
I did trawl the YT posts and found a mention that the resistance between across the plug (wire connection and earth) should be about 2-5 ohms. I measured mine and its about 25. I have a CD manual and tried to find out what a heater plug is - a bit complicated - but I did see that it had a valve and I suppose any valve can leak!
I also noticed the plug manufacturer is specified as a CAV. There are no markings on my plug.
Barry
DavidP, South Wales
12-17-2005 13:18:14
 Re: MF 35 3 cyl 20-30 turns to start in reply to BarryM, 12-16-2005 14:18:01
Hi,
CAV made the originals but because they are changed quite often there are other manufacturers/suppliers who would not necessarily put their name on it.
DavidP
BarryM
12-20-2005 03:28:21
 Re: MF 35 3 cyl 20-30 turns to start in reply to DavidP, South Wales, 12-17-2005 13:18:14
Ok, Ok here is the final and embarassing end to this post!
I rang the guy who sold me the tractor he said the heater plug was new and a waste of time checking - he said just give it more heat - say 40/60 secs.
When I do this (which I never imagined would be necessary) the tractor starts first time.
Its a real joy to have another of these wonderful tractors.
Thanks for all your comments.
