35 gas hours?
CHRIS-MF35
06-01-2000 19:31:18
how many hours can a 35 gas z134 engine be expected to run before overhaul? mine has over 3200, thats when the tach quit, and uses no oil. transmission drips out bellhousing, not bad enough to fix, but 75 hours between oil changes it uses NO oil. this engine has never been touched. i had the valve cover off adjusting valves and do not beleive it had ever been off before. i have pulled double 14 plows, disk, bush hogged, even mow the yard. i have used every bit of power this little engine can mussle, and still no oil use. is this the norm?
thanks CHRIS-MF35
sammy the RED
06-01-2000 23:00:08
 Re: 35 gas hours? in reply to CHRIS-MF35, 06-01-2000 19:31:18
I know a fellow that has a tractor that has around 15,000 hours and motor has never been touched. I know of some others that are rebuilt after 6k or 7k hours. Keep clean oil and new filters in her and keep on tractoring.
Jim
06-14-2000 19:22:58
 Re: Re: 35 gas hours? in reply to sammy the RED, 06-01-2000 23:00:08
Congradulations on the great condition of the engine, don't forget the cooling system should also be flushed on a regular basis say every couple of years, and refilled with correct mixture of antifreeze/coolant and distilled water. sounds like a great tracftor.
