Mf 135 runs bad
Brian
06-04-2000 08:39:55
My 135 has developed a runability problem. when it started it would start running bad when it was hot. If I pull the choke out just a little it will smooth out. Now it wants the choke to be out about a 1/4 of the way all the time. If I push it in it will spit and sputter and lose power. Any ideas?
Allen
08-20-2000 17:27:35
 Re: mf 135 runs bad in reply to Brian, 06-04-2000 08:39:55
I'm having the same problem and wondered if you found any solutions. Any help appreciated.
CHRIS-MF35
06-04-2000 11:34:21
sounds like a fuel starvation problem. filter is stopped up or carb needs rebuilt. check that you are getting good flow to the carb first. the good news is this is a minor repair problem
Danny
06-05-2000 07:33:14
 Re: Re: mf 135 runs bad in reply to CHRIS-MF35, 06-04-2000 11:34:21
Also look for a vacum leak that can lean out the engine and will respond to chokeing the carb.
ALexander
03-01-2001 01:13:39
 Re: Re: Re: mf 135 runs bad in reply to Danny , 06-05-2000 07:33:14
Change the coil.
