1952 Ferguson T030
shuts off
Doug
06-05-2000 08:45:08
After running for 10 minutes the motor just shuts off. I can then restart and it will run again for a few more minutes. I've replaced the coil, condenser, fuel filter. I cleaned out the carburator and checked for fuel flow. I rerouted the fuel line (maybe vapor lock?). I ran without the gas cap, cause I thought it may not be venting, but still no good. Any suggestions will surely be appreciated !!!
Thanks.
Patrick Cline
06-06-2000 05:45:19
 Re: 1952 Ferguson T030 - shuts off in reply to Doug, 06-05-2000 08:45:08
Could it be loosing power for some reason? Does it shut off under certain conditions? I am not much help..I also have a TO30. Mine won't crank at all! It was running fine and now it won't at all. I have also replaced coil, now checking the cellinoid. Battery is good. Any suggestions??
george T
06-13-2000 00:39:44
 Re: Re: 1952 Ferguson T030 - shuts off in reply to Patrick Cline, 06-06-2000 05:45:19
I had the same trubble with my to 20 twice one time it was in the wireing a positive wire insulation rubed off and was tuching the metal another time it the carb nedded rebuliding also I had it hapen when the conection to the wire hooked to the key got lose it ether wouldnt crank or it would shut off when i hit a bump hope this helps
charles
09-23-2001 15:49:38
 Re: Re: Re: 1952 Ferguson T030 - shuts off in reply to george T, 06-13-2000 00:39:44
I have my tank off I have a rock or something in the tank. under a strain it shuts off, sputters,stops. can sit a few minutes cranks back-up.need a tank,or somewhere to clean it out. help
charles
09-23-2001 15:48:04
